Servicing Hope hubs...
[Closed] Servicing Hope hubs - tools
4 Users
I've been watching the Hope video for servicing hubs, of which I have the Pro 2 Evo. There are various kits, and Hope have told me I need this one
http://www.ukbikestore.co.uk/product/423/httpro2/hope-pro-2-hub-tool-kit-complete.html
All good so far, although the description there tells me I also need this
http://www.ukbikestore.co.uk/product/423/htt182/hope-pro-2-evo-rear-bearing-support-bush-kit.html
which Hope never mentioned in their email. Evidently there is something slightly different in the Evo hub.
Then there is the optional support as used by the chap in the video
http://www.ukbikestore.co.uk/product/423/htt167/hope-nylon-wheel-support-bush.html
What would you call the tool he's using to knock the bearings out? I thought that was called a drift, but perhaps not?
Posted : 30/04/2015 10:57 am
I think that tool is just a bit of metal pipe with one end covered in nylon to protect the hub. You just rest the wheel on it so could be substituted with a bit of pipe.
http://www.chainreactioncycles.com/hope-nylon-wheel-hub-support-bush/rp-prod8031?gs=1&gclid=CjwKEAjwpYeqBRDOwq2DrLCB-UcSJAASIYLjcF3LbkRR9K8w77hRLm1QDWygxkA5SLh5FO8ksFHTuRoCcZfw_wcB&gclsrc=aw.ds
When I did this I found out that the freehub bearings didn't have a special tool and hope told me to just use a socket. At that point I figured I should have saved the money on the rest of the stuff and just used sockets for all of it.
Posted : 30/04/2015 11:03 am
EDIT Talking out my hat
Posted : 30/04/2015 11:04 am
I'm surprised they don't sell a complete kit for the Evo, as the two parts on the right of the first link are redundant with the Evo hubs, which have a larger internal diameter, to allow a single axle which is then used with various adapters to allow 9mm, 10mm, 12mm without having to change axles.
The nylon wheel support bush is useful, bot not absolutely essential. I managed for a while using a couple of blocks of wood to support the flanges whilst tapping the new bearings in, but it certainly makes it easier to have something exactly support that surface.
Posted : 30/04/2015 11:09 am
They're not for the front hub?
Posted : 30/04/2015 11:15 am
You only need the special tools for the rear, and pro2 and pro2 evo aren't the same.
You can use sockets on the front, and the free hub, but not the main rear hub bearings (well you can, but it's easy to knacker the bearings!) -
The bearings press fit into the hub shell, and onto the axle at the same time. So if you use a socket, you're only driving in the outer race, and relying on the bearings to drive the inner race over the axle. This can easily damage the bearing - I know from experience.
You need the two on the right for the rear -
They slide over the axle and the flat end pushes in the outer and inner race of the bearing together.
Posted : 30/04/2015 11:37 am
