Sektor Silver Trave...
[Closed] Sektor Silver Travel increase
4 Users
Hi,
Got a pair of 2016/17 Sektor Silvers 130mm.
Is it as straightforward as removing the 10mm spacer from the air-shaft to give 140mm of travel?
P25 on [url= https://sram-cdn-pull-zone-gsdesign.netdna-ssl.com/cdn/farfuture/_hShjZbhHzVhOrODlIg_Ccj-Q5RJXnOeH0uRqilp7g0/mtime:1488218557/sites/default/files/techdocs/gen.4923_service_manual_2016_2017_30_recon_sektor_rev_c_english.pdf ]here[/url]
Posted : 14/10/2017 7:27 am
Yes.... Done the same on a pair of 120's and increased up to 140 with no problems
Posted : 14/10/2017 7:46 am
woo! as they're new I'll wit until they need a lower leg service.
Posted : 15/10/2017 7:03 pm
Does anyone know if this works on 2016 Sektor Golds as well?
Posted : 16/10/2017 6:46 am
Not always possible. I've done a few sets over time. First two were fine, take the spacer out or cut it down and instant increase. Great! The last set didn't have a spacer in, 130mm damper as standard, no way to increase travel apart from a different air shaft. Booo. Worth pulling them apart to check though.
Posted : 16/10/2017 7:08 am
