Hi,
I have a pedal which is seized! And the spindle has been quite rounded now...
Anyone know any tips to get it off? I've taken it to Evans cycles in Leeds and they couldn't do it.
Pedals are ultegra touring and crank is a ultegra 6700, I'd get a new crankset but looking for a cheaper alternative first!
Andy
Picture please ,how does the flat for a spanner get rounded on a pedal ,they are pretty hard ?
It's an Allen key to the back of the spindle
Pic to follow
Hi Andy, if you're in Leeds then these guys will sort it for you...
[url= http://www.rceuk.co.uk/ ]http://www.rceuk.co.uk/[/url]
Highly recommended, cheap, and they love a good challenge.
A600 pedals? could you file flats on the spindle and get a spanner on it ,maybe with a piece of bar over it for leverage ?
Ok I get it now, I could try that, think the spindles are titanium so might take a while to flatten...
I'll just leave these here:
http://www.engineeringtoolbox.com/linear-expansion-coefficients-d_95.html
Hot water on the end of the crank and a new Allen key maybe with a screwdriver jammed next to it
Edit Opps to sliw
Stillsons
If it's properly seized then leverage alone will fetch the crank thread out with the pedal spindle (don't ask how I know 😥 )
Heat expansion first (suggested above) and if it's just awkward/tight then it's a matter of holding one bit still and rotating the other (watch out for the chainring!)
If it's resisting a bit too well then get help (suggested above)
A helicoil, maybe £15 at your LBS, may provide a worse-case solution
I now use lots of grease/anti-seize, don't over-tighten and make regular checks
Had this but with a crank bolt. LBS drilled it out carefully without damaging the crank threads and cost me a tenner.
Good spot. Those are cracks ! Only on the edge of the Allen key fitting on spindle, nothing on the crankarm itself luckily.... I'm guessing we are talking drilling now?
Had the same combination of pedal/crank amd the same cracking of the axle at the hex bolt end - sorted it by disassembling the pedal, grinding some flats on the axle and dosing with some freeze-spray before levering away.
It came out eventually and no damage to the crank 🙂
Oversized Torq hammered in - probably need to remove the crank arm first.
Then a big bar/scaffold tube for leverage?
Smash the pedal body off, grind some flats on the axle, stick it in a vice, heat and go for it
Once the hex bolt end has started to crack, anything wedged, hammered or forcefully inserted will just expand the cracked threads so they bind even tighter.
You have to tackle it from the non hex bolt end, preferably temperature assisted.
stupid question but ... you are turning the right way ?
Yes I've been there and "fudged" that 😉
cro-mo axle and steel insert may mean some corrosion. try a good dose
of plus gas over night and tightening the pedal a fraction to break the corrosion bind.
also a torx bit may provide some extra grip on the rounded bolt head.
Oh FFS - it's caused by the hex bolt end cracking and expanding as you use it to attempt to loosen the pedal.
Any attempt to use the hex bolt in any direction with any tool will just expand the axle and bind it up in the crank thread.
Can't you get the crank in a vice and hammer in a slightly larger torx bit. You could use plus Gas & boiling water to help it along its way
agree with hilldodger.
you need to remove the pedal from the axle and grind/mangle something on that side to get a grip of.
judging by some of your comments above, i recommend you buy new cranks/pedals.
Bloody hell, I don't have access to a workshop - if anyone in the Leeds area fancies a go let me know, can provide beer tokens 🙂
The annoying thing is I bought the bike second hand, the previous owner was pretty convinced they would come off - I don't even want these pedals!! Rant over 🙂
It will be easy to remove the body of the spd from the axle , just undo the nut and pull it off leaving the axle sticking out of the crank arm.
Must admit I did not see the cracks when I first read thread
as some of the posts above
Remove pedal body and use a set of stilsons, no need to file flats etc
You sure there's nothing on the crankarm? It looks like there is one in that pic, under the 175. You can try a few things but I would suggest your cranks are shot anyway.
Why the hell don't shimano use a hexagonal spindle like time etc etc so pedals can be removed with a pedal spanner? I've got a perfectly good xt pedal permanently stuck to a crank exactly the same as OP, I rounded off an Allen key trying to remove it, tried heating, gt85, huge pipe on Allen key for leverage- nowt moved it, boils my pi55!!!
If the crank arms cracked and the pedals rounded why bother rooming it? You will need to replace both the crank arm and pedals anyway so why bother trying to remove it?
I agree the crank arms do look cracked on the photo but I have them a wipe and couldn't see anything after. Might get hold of stilsons
I had [u]exactly[/u] this on an XT crank after someone undid it the wrong way - Stilsons ain't going to touch that mutha!
-Remove crank from bike
-Remove pedal body so you just have the seized spindle left in the crank
-Fire up an angle grinder and grind 2x flats on the spindle.
-Put flats in big vice
-Rotate crank in correct direction if you can't add padding and put pipe over it.
Worked for me - couple of bits of swarf but fine.
Soak the end of the crank in some kind of penetrating fluid.
Take the pedal body off as above, then see if a local engineering company will weld some scrap plates to the axle, or grind it flat on two sides for you.
Clamp in vice and give it all you've got.
With those cracks, I think you'll be lucky to get it out without tearing up the threads though...
They're not, they're steel, if that helps. Unless you've changed them.
So after a fair bit of messing around, I took it to recycle engineering in Leeds (as recommended cheers - good guys) and they sorted it by grinding flats to the spindle and levering it off...
Crank arm threads were luckily ok and I now have my pedals on 🙂
Apparently the previous owner had put them on dry...
Cheers for the suggestions all.
Andy
