seized nipples
[Closed] seized nipples
10 Users
recently got a used road bike and its got a bit of a wobble in the rear. i wanted to true it up but the nipples are seized up. is there a simple way to free them or is it as i suspect just something to put up with til i need a new rim
Posted : 25/01/2015 6:22 pm
Seized when using a spoke key or have you also tried with a nipple driver?
Past truly seized spoke I had, I cut it out with pliers and replaced.
Posted : 25/01/2015 6:49 pm
spoke key i dont have a driver. they are all stuck
Posted : 25/01/2015 6:50 pm
Screwdriver instead of driver? Can't see how a driver would help since in theory (?) during the build the spoke would have come through the nip too far for the driver to engage. Or have I missed something?
Posted : 25/01/2015 6:57 pm
You're buggered, basically.
Posted : 25/01/2015 7:35 pm
New spokes and nipples throughout if you want to save hub and rim.
Posted : 25/01/2015 8:00 pm
thought so i'll leave it as is for now cheers all
Posted : 25/01/2015 8:03 pm
Problem Solvers holy driver, middle tool in this pic. it's got a slotted end that goes around the spoke and just interts into the edge of slot on the nipple
Probably not cheap but maybe you can knock up something similar with a hacksaw and an old screwdriver or driver bit!
Posted : 25/01/2015 8:11 pm
 tomd
Have you tried WD40/PlusGas/Light Oil? Even if it doesn't penetrate all of the thread it will lube the nipple-eyelet interface and reduce the force to get it to turn.
No guarantees, but i've had success in the past with holding a big(150w+) soldering iron on them prior to turning them. Will probably be more effective on aluminium than brass.
Posted : 25/01/2015 9:14 pm
Try mole grips on the nipples, it might be enough to get the wheel straight, if not just cit the spokes of and rebuild.
Have you tried this?
[img] %5D,Imagesize%5Bthumb%5D&call=url%5Bfile:sizer%5D&sink[/img]
Posted : 25/01/2015 9:25 pm
How far will a spoke twist if the nipples are seized? Just wondering as I have a loose spoke and have turned the nipple 180 degrees and it never budged, is twisting a spoke that much ok?
Posted : 25/01/2015 10:20 pm
A twisted, wound up spoke is not a tight spoke, it will just unwind pretty quickly and lose its tension.
I wish I could say the same for some twisted wound up people I know 😉
Posted : 26/01/2015 8:30 pm
Had this a lot when I was a bike mechanic. Take the rip tape off. Put a drop of plus gas in the top of each nibble. Hold it upright for a few seconds to let it sink in. Repeat for each spoke. Leave over night. Use a good spoke key (Spokey with double insert ideally) and try again.
If that fails you'll need new nipples and possible spokes.
Posted : 26/01/2015 9:30 pm
