Seized disc brake p...
Seized disc brake pad pin
9 Users
4 Reactions
Just doing some Sunday maintenance and noticed that the disc brake pad pin has seized in the caliper - noticed by rounding the Allen key head totally...
Anyone got any potential solutions before I bother my LBS with it in the morning?
Posted : 27/08/2023 4:18 pm
Sorry I can’t help and have the same problem. I’m thinking dremel to cut the pin in half and the try and unscrew it
Posted : 27/08/2023 4:21 pm
@chrismac yes, that's sort of my thought. It's a Cure 4 and there is no clearance to get at the head. But if I cut it then the pads are still in there and no clearance to get pliers in the gap too.
Posted : 27/08/2023 4:33 pm
Hammer a torx bit in to the head
Posted : 27/08/2023 4:34 pm
tried a torx bit?  sometimes they will get enough grip to turn it if you hammer one in thats a bit too tight.  Shocks it as well
Soak it in proper disassembly fluid for a few hours (plusgas is ideal, but wd40 will do). Hammer a torqs bit in and then I’d heat it with a kettle full of boiling water. You could also try tightening it to break the corrosion.
Posted : 27/08/2023 4:41 pm
 mert
Aluminium housing and steel pin... Find something that jams in the head nicely then pour boiling water and twist.
Posted : 27/08/2023 4:51 pm
Cut the pin with a Dremel, the back end of the pin should pull out as it's not threaded,just a smooth pin in a hole, pads should then be able to come out to get some long nose locking pliers in, let some penetrating oil soak in if it's stubborn.
Posted : 27/08/2023 6:56 pm
Hammered in a Torx. Soaked in some boiling water. Came loose and out.
Thanks all.
Posted : 28/08/2023 7:19 pm
leffeboy, anorak, footflaps and 1 people reacted
Dremel a slot into the head if torqs doesn’t work. Plus plusgas
Posted : 29/08/2023 3:03 am
Now use a split pin to retain your pads.
Posted : 29/08/2023 6:17 am
