seeping rebound adj...
[Closed] seeping rebound adjuster Rockshox monarch rt3 high volume
1 Users
so i've serviced this 3 times now and each time it gets worse.
Changed the relevant seals and filled with the correct wgt fluid but this rear damper just does not want to play ball!
I would pull the thing apart again but it means having to use a fresh bleed port ball and i dont have just the ball, as far as I know it come with the overghaul kit but I may be wrong.
So to summarise:
seals good
fluid good
ifp height good
rebuilt following instructions
so why it is not playing ball?
Thanks for any help
Posted : 29/10/2015 7:32 pm
