Security - chaining...
[Closed] Security - chaining bikes.
8 Users
[url=
cuttering motorbike chains with ease[/url]
Having watched this vid on another thread, It made me think that if the chain was high enough there's no way it could be cropped with bolt cutters, a noisy cutting disc would have to be used.
When the chain is at anchored at ground level the entire weight of the body can, and seems to be needed, to crop the chain. If a bike were stored vertically on the back wheel, and the anchor plate and chain was at shoulder or head height, it would be hard to place enough leverage. Even if the croppers were placed against a wall, looking at the vid I dont think they would get enough force by pushing sideways to crop a decent chain.
Anyone had any thefts of bikes secured in this manner?
Posted : 24/11/2009 11:12 am
I'm thinking that works if you've got a solid wall to put the anchor point into. I've got breeze block walls and a concrete floor, so it's a risk I have to take. 🙂
Posted : 24/11/2009 11:16 am
surely my dear it easier to prise a anshor off a (single layer) wall than it is from concrete floor.
Some-one did mention torc do a wall specific anchor, might be worth looking at..
http://www.torc-anchors.com/shed-shackle.php
Posted : 24/11/2009 11:18 am
thats exactly how i've installed mine but fortunatly i've never had a visit.
got an oxford docking station at head height then a gold rated chain to lock up two bikes hanging from the rear wheels, enough chain slack is taken up by the bikes that the chain is nowhere near the wall to stop horizontal pressure with bolt cutters, just like vertical pressure used on a chain bolted to the ground
That torc anchor would be ideal but using part of a garage metal structure is also possible. I'm sure lots of people just fit anchor plates at gound level, surely the manufacturers should promote fitting them high up and keeping chain length as short as possible, mine came with no such tips.
Posted : 24/11/2009 11:28 am
so basically considering the generally smaller size/'ardness of bike chains....if they want your bike they'r going to get it?
worries me!
Posted : 24/11/2009 11:37 am
http://www.almax-security-chains.co.uk/index.asp?pg=1
Posted : 24/11/2009 12:23 pm
i think all the chains in that video are 13mm
i use 16mm Torc chains which are guaranteed not to be bolt cropped using a hand held bolt cropper
you can also get 19mm chains as well but these are really heavy
as said many times before if someone wants them they will get them!
Posted : 24/11/2009 12:35 pm
19mm chain. Weighs a tonne, cost a lot, but it ain't going anywhere, which is the point.
Posted : 24/11/2009 1:18 pm
Well thats the answer Almax series 3, At shoulder height! 🙂
Posted : 24/11/2009 5:49 pm
