Securing a bike she...
Securing a bike shed to the side of a house..
8 Users
8 Reactions
I'm looking to free up some garage space and put some of my cheaper bikes in one of those outside metal sheds. I'm not that fussed about security, other than to meet the requirements of the insurance. Which is the shed needs to be lockable (not an issue) and secured to something. Now ideally I'd bolt it to the ground, but it won't have concrete underneath, only stone chips (under which will be soil not concrete.
It'll be up against the side of my house, but not flush, probably a 5 inch gap. I'm thinking somekind of bracket. Does such a thing exist as u can't just screw the shed to the wall due to the gap
Thanks
Posted : 19/08/2024 10:20 pm
I created a kind of ground anchor in my shed by passing a chain through a hole in the floor and out to the side, then into a (very) large plant pot.  A few old padlocks/bits of metal on the end of the chain and then I filled the pot with hardcore and concrete…
Posted : 19/08/2024 10:33 pm
dyna-ti and dyna-ti reacted
Stick some council slabs under it and screw it into them. That's the plan for my Keter.
Posted : 19/08/2024 10:58 pm
Why does there have to be a gap?
Could you part-fill the gap, say a bit of 2x4 or something bolted to the house and then the shed bolted to that if it can't go against the wall completely?
Posted : 19/08/2024 11:06 pm
I would think as an air gap to prevent dampness
Posted : 20/08/2024 1:09 am
Dig a hole underneath and fill ìt with concrete, then bolt into that (or put in a ground anchor for extra security.
Posted : 20/08/2024 5:39 am
^ wot sgn23 said. Hole, concrete and either chain or eyebolt into the concrete.
Posted : 20/08/2024 8:04 am
Thanks folks. I reckon bury some big slabs in the ground under it then attach with bolts should do the trick
Posted : 20/08/2024 8:42 am
Scrounge a couple of RSJ offcuts from a local supplier, might cost you biscuits, and bolt them to the wall and shed
Burying a bucket full of concrete with a length of chain set in would also do the job. Poke the chain through the floor and lock to that
Posted : 20/08/2024 12:08 pm
