Seatpost recommenda...
[Closed] Seatpost recommendations .... A bit of an unusual one.
4 Users
I have a 2013 Trance XO 29er.
The bike has currently got a Reverb fitted that I just don't need so I'm going back to a regular post.
Due to the angle of the ST the Thomson (2 bolt) posts I have, in line and layback, struggle to get the seat level due to a lack of adjustment caused by the ST angle.
I'm after a 30.9 post, ideally with some layback, that has a head on it that would allow for a more extreme angle to be set. Something like a USE sumo but with some layback.
Sadly funds don't stretch to Ti but that would open up some options.
Any suggestions?
Posted : 25/07/2016 6:44 pm
Thomson do (or at least used to do) two different cradles for different angles, which one do you currently have?
Posted : 25/07/2016 6:45 pm
I've just (got an email reply today!) been asking Thomson something similar about their droppers. My 29er needs a saddle to post angle of around 65 degrees.
The Thomson drawings suggests the inline posts have a 29 degree adjustment range which would be a 61 degree angle at the seat tube / post (is this not enough for your Trance?). The setback has less adjustment - see drawings at bottom of this link
https://www.bikethomson.com/product/elite-seatpost/
Otherwise, I've had good results with Ritchey posts with this kind of 2 bolt / curved cradle head:-
http://ritcheylogic.com/comp-2-bolt-25mm-hi-polish-black-seatpost
And posts like the Hope Eternity adjust to almost any angle.
Posted : 25/07/2016 8:02 pm
I run my Tompson lay backs with yokes instead of the stupid squeaky and heavy clamp.
You can get much more angle this way too.
Posted : 25/07/2016 8:14 pm
