Sealed gear ferrule...
[Closed] Sealed gear ferrules?
4 Users
Like these
Would go for the xtr style but it's for internally routed cables
According to this they cause extra drag tho? http://www.artscyclery.com/learningcenter/optimizingcablesetup.html
Posted : 27/02/2016 10:03 pm
Shimano do sealed ones without the nose and boot too. Better than Jagwire ones.
Sealed ones will be dragger than non-sealed initially, but be less draggy longer term as they keep contaminants out better. Lube the cable and ferrules with a dry style lube to beef up their protection and reduce their drag.
Posted : 27/02/2016 10:21 pm
Did not know that the shimano ones were still sealed without the sticky out bit , cheers !
Posted : 28/02/2016 7:51 am
They do a normal looking ferrule but with a seal at the end, I think this might be them: http://www.jejamescycles.co.uk/shimano-sis-sp40-outer-gear-casing-cap-sealed-4mm-id6067.html?gclid=Cj0KEQiA0sq2BRDRt6Scrqj71vQBEiQAg5bj08v0QVG131cZtKT6AtR2qNwIOGzJ-_Yn54fxB_TbugIaAqI68P8HAQ#info
I think I had some other brand ones with o-rngs in the ends once but can't remember the make.
The number of grooves might have something to do with the level of sealing.
Posted : 28/02/2016 10:49 am
Aye.
2 grooves - no seal.
4 grooves - o-ring seal.
Posted : 28/02/2016 11:25 am
Right in gonna have to root through my spares box and count the rings on my ferrules
Posted : 29/02/2016 2:56 pm
I can confirm that the ones andyl linked to are internally sealed. I've used Jagwire kits for the last couple of cable changes but recently bought those Shimano ones and they're worked well.
Posted : 29/02/2016 4:43 pm
