Scraeder rims with ...
[Closed] Scraeder rims with presta tubes...possible?
5 Users
If you have a set of rims running schraeder valves can i use presta tubes instead?
Posted : 11/11/2012 1:38 pm
Yes you can get some rubber grommets for the holes, available online I think I got mine from Edinburgh Bike Coop
[url= https://www.google.co.uk/search?q=presta+stem+saver&hl=en&client=safari&tbo=u&source=univ&tbm=shop&sa=X&ei=YKufUL7JDael0QWgjIHwDA&ved=0CEIQrQQ&biw=480&bih=269 ]Quick google search...[/url]
Posted : 11/11/2012 1:41 pm
Quite a lot of presta tyres come with a step-down valve nut that does the same job, too.
Posted : 11/11/2012 1:45 pm
You don't have to use the gromit things. I have run many a wheel with presta valves in a schrader holes.
Quick fix is to put a few wraps of plumbers or sparky tape round the top of the valve if you are particularly worried about it.
Posted : 11/11/2012 3:11 pm
I don't bother with the grommets either, the valve stem isn't going anywhere
Posted : 11/11/2012 4:03 pm
