Scott Scale headset...
[Closed] Scott Scale headset bearing advice
5 Users
The lower headset bearing on my Scott Scale 29er has gone crunchy after a very short time and on further investigation it turns out to be unsealed bearings in a retainer..
Firstly, is it possible to replace the bearings with sealed ones without having to replace the cup (currently Ritchey Comp Plus Tapered headset)?
Secondly, the dimensions of the bearing are listed as [url= http://www.scott-sports.com/global/en/products/221722/scale-29-expert/ ]40x51.9x8mm[/url].. presumably 40x52x8mm is ok? How about 40x52x7mm which seems to be the Cane Creek standard?
Posted : 07/11/2012 9:55 pm
Sorry, can't help with your query but how are you finding the bike? I'm looking at a scale 910 but haven't had chance to get a test ride yet.
Posted : 08/11/2012 4:53 pm
I do mostly XC on it and love it.. it was my first 29er and first hardtail for several years so wasn't sure how I'd get on with it. A short stem, wide(ish) bars and relaxed (for an XC racer!) head angle mean it's comfortable but still flies!
Posted : 08/11/2012 8:28 pm
I am going to replace mine with these. Think there the correct ones
http://www.chainreactioncycles.com/Models.aspx?ModelID=62162
Posted : 08/11/2012 8:37 pm
Hi Guys, bit of advice, I have the Scale 50 2009 which apparently has 1 1/8" Ritchey OE. Would the above headset from CRC be suitable? Also would I need the Press fit or drop in campy? Absolutely clueless here.
Posted : 12/11/2012 1:39 pm
Those bearings will fit, but if you want the best, then go for the Hope INA-FAG bearings (which also fit).
Posted : 12/11/2012 2:00 pm
Thanks
Would that be:
http://www.hopetech.com/page.aspx?itemID=SPG187
I can't see INA-FAG mentioned
Posted : 12/11/2012 3:41 pm
