Schrader valves in ...
[Closed] Schrader valves in Rockshox forks
6 Users
So I think I need to replace the air valves in my forks. Can I use any old schrader valve or is there something special about the valves used in shocks and Forks?
The reason I think they need replacing is that I get air leaking out when I detach my shock pump- No its not the normal air loss used to register the pressure on the valve its actually releasing the air from the forks- if I don't undo the pump quickly enough I can empty the entire air 'reservoir' and no its not the pump- it works perfectly on my fox shock and the same thing happens with another pump.
Posted : 12/02/2013 4:09 pm
I've used ones from tubes before without problems.
Posted : 12/02/2013 4:20 pm
You can remove the core from a Schraeder valve if you're careful with a pair of fine radio/needle-nosed pliers. Release the pressure on the forks first though!!
Posted : 12/02/2013 4:52 pm
or a valve core remover does it pretty well.
my old nokian inner tubes had a core remover built into the dust cap
Posted : 12/02/2013 5:58 pm
They are exactly the same.
I had exactly the same thing a while ago, the tiny [s]pube of rubber[/s] seal had broken, a new core from an old tube fixed it 🙂
Posted : 12/02/2013 6:01 pm
Just the same thing happened when my shock pump partially unscrewed a valve in my rear shock: (i think I didn't need to screw it on much once the needle went up to pressure) little dab of lube and screwed it back in again.
Posted : 12/02/2013 6:15 pm
Ok great I've got plenty of old tubes lying around, I'll steal one from that. I was a little concerned that it might be a special valve to avoid air loss when unscrewing the pump.
Posted : 12/02/2013 8:01 pm
