Sawing of excess Al...
[Closed] Sawing of excess Alu seatpost...
2 Users
...safe to do? How much should be left as a minimum in the frame?
Posted : 12/05/2011 12:52 pm
are you sawing it to save weight or because it's too long?
in most cases it's the frame that determines minimum insert not the seatpost - ideally you want a couple of inches of seatpost below the top tube/seatstay junction on the seat tube.
other option is to work out what length seatpost you want and just buy one that long, I guess.
Posted : 12/05/2011 12:55 pm
Saving weight. No point spending and throwing away what 5 mins with a hacksaw and some glasspaper can achieve...
Just wanted to make sure it wasnt dangerous.
Posted : 12/05/2011 12:58 pm
it won't be as good as keepign as much seatpost in the frame as you can...
you'll save about 30 grammes - you'd probably save more having a good sneeze before you ride.
Posted : 12/05/2011 1:03 pm
