Sanity Check Hope P...
Sanity Check Hope Pro 4 drive side spacer - Which one?
3 Users
 goby
Hi all,
Ok just changing my freehub on my Hope pro 4 from Shimano microspline to HG to go single speed and just want to double check on the drive side spacer i need.
I have swapped the freehub over to the HG but didnt realise i needed a new driveside spacer, which one is it in need for a 148mm Boost rear end?
This one:
https://www.sjscycles.co.uk/hub-spares/hope-pro-4-rear-hub-x12-driveside-spacer-silver-hub471/
OR
https://www.sjscycles.co.uk/hub-spares/hope-pro-4-rear-hub-driveside-spacer-silver-12mm/
Posted : 23/11/2020 7:55 am
The boostiness is not relevant. Freehub is the same. Its the first one (hub471) according to the tech diagram
Posted : 23/11/2020 8:01 am
The second item is I think the drive side spacer for 135x12 which is different than the 142x12/148x12 version.
Posted : 23/11/2020 8:03 am
 goby
Ah thats good, i was think the HUB471 to!, good find on that tech diagram couldnt find a dedicated 148mm one.
Cheers!
Posted : 23/11/2020 8:11 am
NP. All the tech docs are linked on Hopes site so normally quite easy to find them.
Posted : 23/11/2020 9:20 am
Just run up to same issue. Shouldv’e double checked 🤷🏼‍♂️🤦🏼‍♂️
Posted : 03/09/2022 4:03 pm
