Bottom headset cup is a EC44 but the fork has a lower dia of 1.25".....
Struggling to find one that will fit or can I get crown race adaptor?
1.5" to 1/-1/8th is common but haven't seen this size????
Any help appreciated
This is the one you need but sold out at Charlie
http://www.charliethebikemonger.com/cane-creek-40-series-ec4433-conversion-headset-bottom-assembly-black-11363-p.asp
I also got in a muddle with this and got a hope headset. I had to have a spacer/shim thing machined to make it work.
http://singletrackmag.com/forum/topic/headset-confusion-help-needed
l.e. The crown race was in stock when I posted, seems someone ordered it in the meantime :).
Enve do a 1.25>1.125 fork.
Second easiest would be to get a EC44/30 bottom and have the crown race ID machined to 1 1/4.
Alternatively, as RichT mentioned, use an [url= https://www.merlincycles.com/hope-hs136-15-1-1-8-reducer-57832.html ]adapter[/url] (machined to 33mm ID) and a standard EC44/40 bottom.
Also, [url= http://www.ebay.co.uk/itm/Cane-Creek-40-Series-EC44-33-Conversion-Headset-Bottom-Assembly-Black/272545943723 ]ebay[/url].
@austinburner just spent all afternoon trying to sort out the same problem on my Salsa Vaya and as advised by otsdr I seem to have bought the last one from Charlie the bikemonger. But I think I might have another solution and might not need it so email me
Ben. Emailed you.
