Mmmm, not sure about this
Carbon frame with 34.9 dropper, tag along clamp does not fit 34.9 post (fitting goes up to 31.8) and I don’t want to clamp on dropper anyway.
So can take dropper out, put in a 34.9 to 31.6 shim which is 120mm deep with a 400mm 31.6 post with at least 200mm in frame and fit tagalong
? Would you, ta
Posted : 31/10/2020 9:16 am
Provided the shim is long enough to extend below the top tube junction, I'd have absolutely no problem
Posted : 31/10/2020 9:27 am
Top tube is about 60mm below clamp, and have just found 150mm shim, cheers
Posted : 31/10/2020 9:49 am
