Tips welcome
Son has Scott HT with standard saddle fittings. But sadldle keeps working loose. First obvious solution was to tighten the bolt underneath the attachment that seems to hold the two holding bits tight. Ok this works for 2 minutes and then the sadlle becomes loose again
Sounds familiar? Trying to avoid trip to evans......(where it was bought)
Is it working loose or it the seatpost cracked at the clamp?
Threadlock if the former.
No working loose. Did the obvious (tighten bolt underneath). Just took down to evans for a proper mechanic to check it and he did the same thing, if it works loose again, I guess it's a new seatpost?
Thanks
