To get the saddle level I use the Angle Finder app and try to get it straight by having it 4-5 degrees tilted down at the back and 4-5 degrees tilted up at the front. Is this the right way to get it level ?
Anyway the seat post clamp keeps failing to keep saddle straight. After a few rides of sitting on the saddle I notice that the tilt angle has gone back by itself by a few degrees after starting to notice that it feels very uncomfortable. Anyone know why and what could I do to stop this?
if its the same head type as the one above, then buy some fibre grip, dis-assemble the clamp and apply some to the tapered blocks that are squeezed into the post head, then adjust it and do it up tighter than a tight thing (and then a bit more)
if its a 2 bolt post head (thomson for example) then the bolts must not be done tight enough, but to get the movement you are describing the saddle would flop around.
if its a single bolt head post with serrations, buy a new post...
