I usually use carbon paste but am chasing out a saddle/dropper noise. I’m wondering if grease might be a better option on the rails ?
I have never used anything in over 25 years and never had a creak from saddle rails.
I would suggest cleaning and nothing.
Hmmm, ok, may try that. It’s a Fox Transfer dropper, Thomson bolt up clamp, ISM saddle on a Bird Zero TR. post itself has carbon paste on it. I have exact same setup on my Anthem and it is silent.... Not convinced it’s the rails but that’s my starting point. It’s definitely saddle or post as doesn’t do it when standing and pedalling, or when sitting and pedalling on road. Does it whether pedalling or freewheeling.
swap the saddle with the one on the Anthem as a test?
A tiny smear of grease or copaslip. Not carbon paste. I usually leave it dry tho.
Leffeboy - good plan ! Will go with copper slip too, thanks
Try the rail/saddle base interface. Dribble some oil in there to check.
Good point, thanks
Dry .. Any type of grease/oil attracts dirt then creaks !!
Whenever I get squeaky rails on my Reverb a dab of Copperslip does the trick.
I had a similar creaking recently. After taking the saddle off, cleaning and greasing twice - still creaking. Swapping the saddle - still creaking.
It turned out to be some dirt where the Reverb goes into the seatpost. Remove, wipe, put back - no more creaks!
Never greased saddle rails despite that fact that I will add oil/grease/silicone etc to virtually everything that gives me an excuse to! If it's the saddle rather than the post or the frame/post then playing about with the saddle tension should change the nature of the creak. It can be infuriating tracking down a mystery creak, so just eliminating one cause at a time is the way to go.
Water pump grease is what you want for creaky saddle rails.
Cheap as chips and really difficult to actually spread on anything it's so thick.
Stops any trace of a creak dead in it's tracks and won't wash off any none moving connections like a boss...
Some good ideas, thanks all. The hunt will commence tomorrow once it’s all dry after today’s ride and wash down...
