So as Advised a couple of week's ago,
I've just purchased a Deore 12-36t Cassette to use on my 1x9 set up (32t Chainring),
It's just occurred to me that I may have an issue running my short caged xt mech on such a large sprocket?
Can anyone please clarify if this desired set up will work?
I've also read the 12-36 is designed for 29ers, This shouldn't be an issue, right?
11-34 gives a wider range, weighs less and won't incur mech issues. I'd return the 12-36.
I would benefit from the 36 over the 11.
What Mech issues?
Yep, the only point of 12-36 is either to bodge an 11-36 cassette, or deal with too-high front rings. Instead of going up to 36, it's better to go down at the front.
But to answer the actual question, it's an It Depends- Shimano shortcage is very short, it'll be long enough for some frames but if you've got a chaingrowthy design, maybe not.
(I didn't know there's a shortcage XT)
Does "short cage" XT Mech even exist?
Shimano's "short" cage XT is a medium by anyone's standards.
Either way, Zee/Saint/SRAM short cages have no issues with 11-36 so can't see an issue with 12-36
honourablegeorge - MemberEither way, Zee/Saint/SRAM short cages have no issues with 11-36
They do- not compatible with all frames, they can't take up the slack of some designs with lots of chainlength change. Does seem rare though.
Yup, On closer inspection I currently run what appears to be a Medium caged.
So let me ask a new question,
Will my Medium caged rear mech have an issue running a 12-36t cassette???
I've been told otherwise, Wouldn't dropping to a 30t from 32t be minimal difference?
Sounds like a job for the [url= http://sheldonbrown.com/gears/ ]Sheldon Brown gear calculator[/url]!
My medium cage XT is working fine with a 40t T-Rex so you'll be ok.
If the XT mech is a Shadow model they are designed to run with a largest sprocket of up to 36T so you will be absolutely fine.
32/36 is near as dammit the same as 30/34.
FWIW, 36/32 gives the same gain ratio (1.7) as 34/30. 12/32 gives a slightly lower gain ratio than 11/30. So with 11-34 and a 30t you actually have a wider spread of gears than 12-36 and a 32t.
Where can I get a Dummies guide to bicycle gear ratio's
Confusion!
Sounds like a job for the [url=sheldonbrown.com/gears/]Sheldon Brown gear calculator[/url]!
I'm not sure but here are some pointers
my understanding is that "capacity" is the issue - the ability for the rear mech to take up slack
the late great Sheldon Brown defines it here
[url] http://sheldonbrown.com/gloss_ca-g.html [/url]
but as single front ring capacity is 36-12 = 24
Shimano includes capacity on their tech sheets - not sure what XT mech talking about but suspect its the GS (shortish?)one here or find shimano number on your mech and google it with shimano tech sheet
[url] http://techdocs.shimano.com/media/techdocs/content/cycle/SI/RD/SI_5W70A_005/SI_5W70A_005_En_v1_m56577569830655487.pdf [/url]
which has a capacity of 33 so no problem with 36-12 other than the spec lists max rear cassette as 34 - this is where trial and error play and messing with the b screw - answer I suspect is probably yes as spec sheet wasn't really written with single front perspective - hopefully someone has run it and will come along - beware people who have got away with it on ten speed - they were designed for 36t - running above 32 with 9 speed is pushing it in my opinion
Rubbish, non-Shadow mechs were designed for a 34t, Shadow mechs were designed to work on 36.
GS will be fine, SS would perhaps have been pushing it, but as said, they don't do an XT SS mech.
[I]running above 32 with 9 speed is pushing it in my opinion[/I]
[URL= http://i573.photobucket.com/albums/ss177/misterp13/20140423_140337_zpsa36aae14.jp g" target="_blank">
http://i573.photobucket.com/albums/ss177/misterp13/20140423_140337_zpsa36aae14.jp g"/> [/IMG][/URL]
The Shimano tech manual states that a 9 speed Shadow XT mech is designed to work up to a 36T.
Yup, there's some contradiction as Shimano used to claim 36 tooth wouldn't work with their 9-speed mechs, and you had to upgrade to 10 speed for that. Then they decided to make a 36 tooth 9-speed and suddenly the guidance changed 😉
So why do they make a 9sp 12-36 cassette then? 😉
I looked into exactly this question recent when building a touring bike for Mrs PP. We want LOW gears and a 22/34 bottom gear was always fine on her 26in bike, but I bought her a 700c bike, so a rethink was needed. No way was I going 10sp for touring, but Shimano make a 12-36 cassette which was originally intended for 29er MTBs
Fine
But a normal Deore M591 mech will only take a maximum 34t sprocket, so I had to change the mech to an M592 to solve that.
I don't think they make asp XT mechs any more, certainly I couldn't find anything better in stock at Madison (I work in a bike shop, I can see what's available) although it's possible there may be old stock lying around
PeterPoddy - MemberSo why do they make a 9sp 12-36 cassette then?
That was kinda the point, everything up until that came out said "can't be done, max 34T, you need 10 speed" then they decided to sell a 36T and suddenly it was all good. Cheeky beggars that they are
I have a XT M771 which is a none Shadow mech and looking at [url= http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Deore-XT/SI_5W60A_002/SI_5W60A_002_En_v1_m56577569830648262.pdf ]this[/url], It'd seem I'd be pushing my luck,
Thoughts on weather I should push my luck and try it? 😕
You didn't look very hard then, RDM771GS and SGS both have good stock at Madison, found in one search! Hopefully you'd look a little harder if you were checking for a customer 😉
Tried to change my order from 12-36t to 11-34t but it was too late,
Question is should I just send it back or should I give it a go?
Fair enough, no I didn't look that hard to be fair. I wanted Deore anyway. 🙂
So thoughts on running a 12-36t on a non shadow M771 mech that officially clonks out at a 34t?
Should I send it back for a 11-34t or is there a viable chance it'll work, maybe with longer B-tension screw?
I think you'll be fine but the only way to find out is to try it.
I run 12-36 with a Saint 810 short cage mech no problems.
The Shimano tech docs showing max size sprockets are a bit of a puzzle and probably err on the side of caution.I have run bigger sprockets on both 8 and 9 speeds no problem.I am also sure I have seen new(road) bikes specced with sprockets bigger than the tech docs guidance too.
shimano are often vastly conservative on their max/min limits - I've run a road rear mech with a supposed 11-28 max cassette size limit, with a 11-34 no problem!
Sounds promising, Think I'll give it a go.
