Hi,
A simple question.
For RS forks with the X loc - can you get it for the right hand side of the bars ?
I've only ever seen left....
Do you mean the other way round?
Only the Revelation XX WorldCup Dual Position came in through the UK distributor with a Left sided X Loc. All other 2012s and all 2013s are right hand.
Nothing stopping you running it upside down on the other side though.
Really ?
Just to be clear the X loc mounts on the right hand side of the bar with the rear shifter ?
Every photo i've seen shows it mounted on the left.
That will be good then as my monarch xx remote occupies the left side of the bar.
Yup, the older silver version tended to come on forks as a left side so these might be the pictures youve seen. But yes all 2012/2013 UK aftermarket forks (other than the one exception i mentioned above) come with a RH xloc remote. So yes can be direct mounted with rear shifter (and various elixirs) on the right.
Great, thank V much for the info.
