RS Shock Eyelet wit...
RS Shock Eyelet with Bearings - Remove / Replace
4 Users
 NS
I have a Rockshox Vivid shock that has a bearing eyelet on the lower shaft end (30mm x 8mm bearing mount).
I would like to fit the shock on another bike that fits a 40mm x 8mm standard DU bushing eyelet on the lower end of the shock.
Does anyone have any experience of this - Is it possible to remove & replace the bearing eyelet on the Vivid & if so any recommendations on who could do it for me?
I am not sure if another viable option would be to fit 5mm spacers either side & retain the bearings as they are? Or would this put too much stress on the 8mm mounting bolt?
Thanks.
Posted : 18/08/2024 4:08 pm
https://www.tftuned.com/rockshox-deluxe-super-deluxe-40mm-bearing-dust-cover/p4111
Bearing mount spacers
Posted : 18/08/2024 7:34 pm
Yeah that link looks to be what you need. Otherwise it's a new shaft for the shock so full service plus the part ie. £150+
Posted : 18/08/2024 8:07 pm
 NS
Superb, thanks guys - wasn't expecting a £6 solution to the problem!
I'm guessing I just need to source a 40mm axle pin now to slot inside the bearings/spacers?
Any recommendations on good manufacturers or should I just purchase a RS 40 x 8mm mounting hardware kit and not use the top hat spacers.
Thanks again.
Posted : 19/08/2024 2:33 am
No, the bearing pin sits between the bearings on the RS mount I believe rather than passing through (the frame bolt does this) so just the £6 part linked.
Hope that's what you mean and should be easily checked with a quick look at the 8x30 setup
Posted : 19/08/2024 8:30 am
Hello mate, just seen you Lyric Ultimate forks for sale in classifieds. I'm in Glasgow too, keen to take them, but the private messages aren't working properly on the site. I can't send you a message!
I'm also in G66 (Lenzie) could pick them up today if it suits. Could you try pm me or email me at:
graememartinATlivedotcodotuk
Cheers!
Posted : 19/08/2024 11:53 am
 NS
OK great, thanks.
Posted : 19/08/2024 4:00 pm
