RS Revs Solo Air to...
[Closed] RS Revs Solo Air to DP coil - not possible?
3 Users
 sv
Apparently cant be done to a set of 2013 150mm Revs, anybody tried it? Previously converted a set of older ones from air to uturn no problem.
Posted : 28/05/2014 2:11 pm
I've converted 2012 Revs dual air to Sektor DPC Coil so don't see why it can't be done.
Posted : 28/05/2014 2:17 pm
 LoCo
Yes but liekly to loose 5 to 10mm travel due to the negative spring assm if set at 150mm, unless you make a hybrid rebound damper, that's very expensive to retain the dual flow/rapid recovered rebound setup.
Posted : 28/05/2014 2:23 pm
 sv
Thanks for the info Simon.
Posted : 28/05/2014 2:33 pm
