RS Revelations - DI...
[Closed] RS Revelations - DIY removing PushLoc and dropping travel
3 Users
I believe its possible to DIY remove the Pushloc and replace it with a normal RS blue compression adjuster. Anyone got any experience of this? or any links?
And dropping the travel from 140mm to 130mm or 120mm just requires a new air shaft at around £30, yes?
Ta
Posted : 07/12/2015 10:23 am
What year are they as my 2013 150mm rct3 just use a spacer to change the travel?
Posted : 07/12/2015 10:27 am
2015 140mm RL
Posted : 07/12/2015 10:31 am
Not sure if mine are the same but to the remove the remote lock I just took off the cable, pulled the assembly out of the right hand leg and unhooked the return spring. Didn't bother changing the knob as its easy enough to turn.
Guide
https://drive.google.com/file/d/0B1AoGIWBz4H1YWNhYWRkODYtNzRiNi00YTA1LTlmMjctNmQzOWQwMDdiZGFl/view?hl=en&pli=1
Posted : 07/12/2015 11:02 am
