Following a 'good idea' I had on the trail I have lost the grub screw that holds my rebound adjuster in on my 2015 Pikes
Just the grub screw, the bit the allen key is in here:
I could just buy the whole adjuster from SRAM (£20) but all I need is the screw.
Anyone had any luck getting hold of one (not 50) online?
Apparently it's an "M3 .50 Pitch set screw"
Ta
Send me your address by PM and I will send you one.
Have a look on eBay. You could pick up a few, probably in stainless for a couple if quid. Also, check the threads as that might be the read on the set screw came out. I've seen a few with weak threads in the adjuster. I ended up helicoiling mine.
Hmm - I need some spares of these, anyone a link to the correct ones
Had a quick search on eBay, m3 x 5 mm, is that right..?
