RS Pike RC damper t...
[Closed] RS Pike RC damper to Revelation - possible ?
4 Users
Hi
I have a 14 Pike RC with charger damper and a 18 Revelation RC with the moco damper.
Can I put the Pike damper in the Rev or easier to buy a new charger 2 kit ?
The moco damper is pants and spoiling the ride of my Chameleon
Ta
Posted : 02/02/2019 7:34 pm
The charger 2 damper should fit and the revs can accept that damper so I think it should.
Posted : 02/02/2019 7:38 pm
Its complicated as there's a ton of different 'A' Pikes, but I am guessing yours would be non-boost, in which case the damper won't swap into a more modern fork.
Posted : 02/02/2019 7:56 pm
I thought you could upgrade A1 and A2 pike to charger 2
Posted : 02/02/2019 8:26 pm
Might just get a charger 2 for the Rev then as sounds easier
Posted : 02/02/2019 8:31 pm
You can upgrade all 35 forks to charger dampers, but you probably can't put the damper from the OPs pikes in his Revs.
Posted : 02/02/2019 8:48 pm
Impossible. A Pike RC 14 will be none boost with a far more corse top cap threading. The Revelation has a very fine top cap thread, RS changed the Pike to this same thread but only on the A2 boost fork, the Lyrik B1 has always had the fine tread.
Posted : 02/02/2019 9:45 pm
