RS Pike Air Shafts
[Closed] RS Pike Air Shafts
6 Users
I need a new fork and I'd like a Pike but it needs to be 130mm.
I know the part number I need for the change (11.4018.026.010) and I'm pretty sure I can do the change myself.
Problem is the part, none of the LBS's have been helpful, Loco's a very busy man and unless it's from the States I can't find them online!
If anyone can help, that'd be great 😀
Posted : 22/12/2014 2:02 pm
You can buy a longer one and machine it down - I've just done that to reduce a 26" 150mm Pike to 140mm. There's an online guide if you google for it.
Posted : 22/12/2014 2:07 pm
I'm sure you can but unfortunately my machining skills are the square root of zero 😀
Posted : 22/12/2014 2:13 pm
My Pike 29er 150mm air shaft is a chopped 160mm one but it was supplied by Loco so that’s not really helpful, sorry. Have you tried TF Tuned or any other suspension service and tuning companies?
Posted : 22/12/2014 2:21 pm
Zee germans usually have them.
I'll have a look for you.
Posted : 22/12/2014 2:31 pm
Cheers, but I couldn't find them, maybe my googlefu isn't with me today!
Posted : 22/12/2014 2:35 pm
Here you go.Found them for you.
Yours should be in there.
[url= http://www.mountainbikes.net/mtbikes/produktlistek.cfm?ctry=1&za=1&lc=1&curcd=1&cid=72702AE0-5056-B502-E562923E5E302409&katid=1190&PNR=24667&gbnr=190 ]link[/url]
Found by doing a google (singletrack pike air shaft) search.
God i have a good memory... 😉
Posted : 22/12/2014 2:41 pm
I had found them but out of stock like everyone else.
Posted : 22/12/2014 2:51 pm
Fail. 😳
There's a big polish site that sells them.I'll try again. 😉
Posted : 22/12/2014 2:55 pm
If I read your part number right, you need the 140mm 26" shaft - I think they've only recently started doing them I think - there's a new 140mm Pike dirt jump fork right? - but if you can find a 150mm 26" shaft, you simply need to remove 10mm from the bottom, I think the thread is long enough that it doesn't need to be tapped, so it's just a question of shortening and installing. I'm guessing it's for a 650b?
I went through the same thing looking for a 140mm 26" shaft and eventually ended up doing that because at the time, they simply didn't exist in the real world.
Have you been in touch with LoCo?
^ Loco.He did one for me.He'll get you what you need as well.
Give him a call.
Job done.
Posted : 22/12/2014 3:02 pm
BadlyWiredDog - Member
Correct, however, like I say I won't be doing any chopping myself, don't have the tools and definitely don't have the skill.
Loco's busy moving workshops so isn't contactable. I've emailed him about another issue but haven't had a reply, which is understandable.
I may buy a cheap cheap stopgap until I can easily sort the parts needed.
Thanks for the responses.
Posted : 22/12/2014 3:29 pm
Any LBS will be able to order you in one if they have a Fisher account
650b, 130mm is, part number R8026010,, Its out of stock
26" is part number R8026011, out of stock
No dates shown on them
Posted : 22/12/2014 4:29 pm
What size fork you after? I am after a 130mm 29er Pike, Fisher have confirmed this is the stock part I'd need for that. http://www.fisheroutdoor.co.uk//product.asp?category=840&part_no=R8026000A&find_category=&find_description=&find_part_desc=R8026000A
TF will do a travel change by machining the existing one down for £60.
Posted : 22/12/2014 4:39 pm
