RS Monarch Plus RC3...
[Closed] RS Monarch Plus RC3 - Knocking feel/sound??
7 Users
I've got a problem with the shock on my Mega 275 2016 Frame (RS Monarch+ RC3), it's started making a knocking noise (you can also feel it) as the the stroke changes from compression to rebound. I have checked everything else it could be and I'm 100% its internal in the shock body.
Suggestions what to do or is it normal?
Posted : 18/07/2016 5:18 pm
It's very a common problem. Send it back under Warranty it is the only real answer.
Posted : 18/07/2016 5:20 pm
Yep common, was told it was normal, never rated the debonair plus as much as the monarch plus it replaced.
Posted : 18/07/2016 5:26 pm
Thanks guys, will be in touch with the shop in the morning.
Posted : 18/07/2016 5:52 pm
I'd love to know what is causing this,I've got an out of warranty one with exactly the same issue
Posted : 18/07/2016 8:50 pm
James at Jtec will fix it, and tune it for about £40, if it doesn't need a service.
Posted : 18/07/2016 9:12 pm
Had this problem and Fishers replaced the whole unit under warranty as they couldnt get the individual parts for months. Very good service from them. Originally I thought it was the reverb as it has some "squish" in it, but it turned out after having the reverb replaced to be the shock. Bloody annoying it was on any bumpy downhill. Good luck
Posted : 18/07/2016 9:34 pm
