On trying to fix some Rock Shox Lyrics. I have taken off the slow speed compression dampener to clean it as it was gritty and a small amount of oil was coming out. I only took off the top caps and circlip, i didnt remove the whole unit from the fork.
On reassembling the slow speed adjuster it does not click anymore? I take it the spring and ball bearing have popped out but where is it located in the dampener unit? Is it easy to fix?
Cheers.
Posted : 12/05/2013 8:20 pm
