RRPs and Stanchion ...
[Closed] RRPs and Stanchion wear
6 Users
Has anybody had problems with RRPs and stanchion wear? I had a bad experience recently, looking at the RRP fitted it seems like it deflects a lot of rubbish into the seals between the bridge and stanchion?
Posted : 31/08/2012 2:31 pm
Muckynutz Fender Benders are a much neater solution. Although I don't think they're quite as robust as the Neoguards.
Posted : 31/08/2012 2:33 pm
Hi
Someone I know had some really bad stantion wear occur which we couldnt really explain-it happened over very short period of time.
One possibility was the Neoguard either rubbing/flapping or deflecting grot.
Not happened to anyone else and lots of our bikes have them so not sure
Steve
Posted : 31/08/2012 2:36 pm
My RRP definately caused more mud to build up around the stanchions. Not usually massively, though. Not sure if it made any difference, but the Bender Fender does a similiar job and didn't cause that problem so.
Posted : 31/08/2012 2:39 pm
The muckynutz works better as a mud guard and keeps mud OFF the stanchions. Defo a must have in my opinion.
Posted : 31/08/2012 3:33 pm
I've had much the same experiences with RRPs and Bender Fender. The only thing I'd say is not to use Bender Fenders with Magura forks; it blocks the area between the braces where debris would normally escape.
Posted : 31/08/2012 3:40 pm
