Hi,
Will be swapping over brakes from a mineral based set to Dot.
1) Any tips on how to swap the rear cables over?
Or can i just reuse the existing routed cable if I flush the old mineral oil out with Dot?
Tips welcome
Kwack
Posted : 09/05/2019 8:24 pm
I would use a reverb hose tool if possible to connect the old and new hose together and just draw through.
You can stick a gear or brake inner cable up the old hose and push/pull so you have a guide for the new cable.
I would not reuse the hose if switching from mineral to dot.
Posted : 09/05/2019 10:45 pm
