Routine maintenance...
[Closed] Routine maintenance on a FS
5 Users
What should I be doing and how often?
Posted : 28/02/2018 10:11 pm
Depends on the bike. Do you have pivot grease ports?
Was clean lube the moving bits and keep ridong.
Make sure you check bolts to see they are tight
Posted : 28/02/2018 10:14 pm
How sensitive are you to changes? I don't check bolts as they don't often come loose and I notice when/if they do. YMMV.
I just look after the shock as I do the forks and watch for anything sticking, rattling or knocking.
Posted : 28/02/2018 10:23 pm
Squirt some silicon lube on shock seals?  A dribble of proper oil into pivot bolt/bearings now and again if I remember?
But mostly just brush off any mud and never aim the jet wash at pivots or bearings.  Treat like any other bike.
Posted : 28/02/2018 11:59 pm
I've had bolts come loose on my Trek.  However they've conveniently had torque settings laser etched on the caps - thanks Trek!
Other than that I just spray Fork Juice on the shock shaft but it probably doesn't need it.  Nothing to do really.
Posted : 01/03/2018 12:04 am
