[Closed] Rotors?
8 Users
 ajf
There all the same right?
I ask as some rotors say for this brake or that brake, but essentially at a base level its a metal disc attached to your wheel.
I should just choose a balance between price, weight and fancy pattern?
Posted : 26/02/2015 9:36 am
Basically although some wear a bit funnily due to the hole pattern. Shimano make a good general one.
Posted : 26/02/2015 9:46 am
Some are wider and some are thicker.
Posted : 26/02/2015 10:09 am
All discs pretty much universal. Only ones to be aware of are the certain hopes which have a slightly thicker disc, V2 and V4. Shimano ones are pretty cheap these days in both plain and floating. Superstar floaters if you want some colour.
Posted : 26/02/2015 11:38 am
Some are lighter too, but basically... yes.
Posted : 26/02/2015 11:40 am
I've had some really poor braking performance when I've used very light weight rotors.
Is it a truism that the very light rotors don't perform as well as the less holey??
Posted : 26/02/2015 12:09 pm
I found that my kcnc rotors didn't brake as well as the avid xx floating rotors.
What I'd really like is a lightish rotor that still brakes well. Moon on a stick I think though.
Posted : 26/02/2015 12:14 pm
I found Avid ones from a few years ago tended to warp. Not had that problem with Shimano ones.
Posted : 26/02/2015 12:23 pm
