Rotor rub - fork fl...
[Closed] Rotor rub - fork flex or something else
5 Users
I've got a Charge Plug 5 road bike and when I'm riding out of the saddle I get a reasonable amount of rotor noise. Is this likely to be the wheel or the fork or something I'm missing? If it's the fork I guess I can just buy something more rigid in carbon but on a newish bike that seems a bit stupid.
Posted : 29/04/2015 2:59 pm
Could be the hub bearings, I get it when my cup and cone bearings need adjustment.
Posted : 29/04/2015 4:03 pm
Spokes catching the caliper body? My spyre front slightly does this and I'm going to have to space the rotor over a bit.
Posted : 29/04/2015 5:02 pm
Is that the pads rubbing the rotors? Assuming so and not the calliper clipping the spokes. If it is the pads, try this: loosen the calliper bolts so that it is a bit jiggly. Give the wheel a slow spin and while it is still spinning pull the lever. This should centre the calliper. Tighten the bolts back up and see how she goes.
Posted : 29/04/2015 5:49 pm
Sounds like the forks flexing. My rebas with QR do this but my Pikes with 15mm don't. If they are QR check it is tight.
Posted : 29/04/2015 6:04 pm
