Hi, i'm running a sram red at the mo with a chris king BB, can i use the BB with a rotor 3D crankset?.
cheers
As far as I know you can't as Sram is a GXP fitting, correct?. The Rotor BB is the same size as a normal Shimano fit (i.e. different to Sram'sd GXP).
Someone will no doubt correct me if I am wrong
And that someone is me DanW 😉
Looks like the only difference for a SRAM chainset is that the BB doesn't come with BB spacers and there's a couple of washery-type things that won't be needed. Have a look [url= http://chrisking.com/bottombracket ]here.[/url]
I'm using a Rotor 3D with a Chris King BB.
Here's a pic with the Chris King BB and a Rotor Agilis chainset. The only thing I had to do to fit the 3D was remove the BB spacers.
Does Sram Red not use a different size BB like the MTB components then Lardlover? Shows how much I know! 😀 Sorry to be so useless turneround!
P.S. How do you guys like the Rotor cranks? They look like great weight/ value/ Q-factor and I have been strongly considering these for the MTB
Yes it does, GXP BBs are not compatible with HT2. However, the King BB uses adapters to make it GXP, which can be removed to run Rotor cranks.
Also very tempted by some 3D cranks so I can use a Power2Max power meter.
Ah ha, so I'm only a semi-numpty 😀
I like the look of Rotor cranks but am a bit put off by the fact you don't see too many (or any actually!) around. XTR cranks are just such an easy choice
jep, just wanted to check as i havent taken off the red cranks since i had them - thought it was a case of just removing the spacers
ta
anyone want to buy a 170mm set of mint sram red standard cranks 🙂
I know a couple of guys who use them, both on and off road, nary a bad word to say about them really.
How much are they? I saw them on Wrench Science for $400 but wondered what they were over here
£400 with rings from velotech 🙁
Only £250 for the cranks though.
Really? And they can be run with normal (ie not Rotor) rings?
Correct.
managed to bag a 'new' set of 3D cranks with ti axle, ceramic rotor BB and q rings for £300 on Bike radar... happy chappy...
