Want to head from Sheffield to Doncaster off road.
Sheff to Rotherham seems ok on 5 weirs or the other loop. Mexborough Pastures I can pick up the Transpennine trail in to Doncaster. I could loop north from Sheffield to Chapeltown on NCN6? to where it meets TransPennine near Elsecar. If it's possible though I'd like to follow the river. Any ideas? Or alternative low traffic routes. Thanks.
Bit late for an evening bump, but that's what it is.
You can get from Mexbrough behind the earth centre head upto towards Sprotbrough go through Steetley quarry,to the hair pin bend,the dons on ya left all the way,then,pick up the trail under the motorway bridge on the a1m at warmsworth,then onto the Ridge,you can go down the old lines ,or follow it down the side of the Don & the canal onto the north bridge in Donny !.
Then where dya wanna end up ?.
It's the bit through from the stadium area right through to Swinton. Is the canal tow path or riverside passable these days? I tried about twenty years ago but the steelworks at Aldwarke fence came right down to the bank and you couldn't get through, similarly I think it was blocked by scrapyards or something on the other bank. Would just be nice to be able to follow the water.
To be fair I don't know,ya could be right,as there's been loads of re-development ,Parkgate-Kilnhirst-Swinton etc so can't really help,besides I try to keep away from there if I can !..
bump can't give a definitive answer - used to live below Wharncliffe and would regularly ride up to Silkstone thru the woods and on mostly quiet roads and then out beyond Doncaster on the TPT
though not in area keep up to date (sort of) cycling issues and recalled this
[url] http://www.cyclesheffield.org.uk/2014/11/14/closure-of-sheffield-canal-towpath-safe-cycling-compromised/ [/url]
which is a long term closure of canal route to east of Rotherham
hope someone local can suggest a good compromise route
