roof bars and bikes...
[Closed] roof bars and bikes...
6 Users
so if i get some roof bars (i.e. NOT a specific bike carrier, just some bars which go across the roof) for my friends ford Ka, can i just strap bikes to it (with some insulation pipe protection)?
obviously it would be strapped down properly.
can't really afford a proper bike carrier, and we plan to take a tandem on the roof anyway...
can't see any problems really, can you???
Posted : 03/05/2010 2:09 pm
noone?
Posted : 03/05/2010 3:09 pm
I wouldn't, the force of the wind is not to be underestimated.
I've had a tyre pulled off the bead by a motorway cross wind, while the bike was on a proper carrier.
That said it would depend on how fast your going to be driving.
Posted : 03/05/2010 3:16 pm
surely thats a risk with any roof mounted bike carrying?
i'd have thought that with a bike on its side, wind would be less of an issue than if its stood up?
Posted : 03/05/2010 3:18 pm
You'd be surprised at the forces going through things on a roof rack. Given you plan to do it at points it isn't designed to take those forces, then it is your adventure. Then again, I've seen what happens when you don't secure loads properly for freight movement so I probably over-restrain everything I move.
Posted : 03/05/2010 3:21 pm
True, I'm more than a little paranoid about the bike being on the roof anyway, so more likely my fear than a real one.
Some good straps and a bit of care would probably be ok.
Posted : 03/05/2010 3:33 pm
not dismissing what you say, but i don't quite understand.
the rack i plan to get (a mont blanc one) has the bars which go across the roof. to these, one could attach a bike carrier thingy, which would be attached at 2 points to the roof bars. the bike would be held vertically up.
i'm planning on lying the bike horizontally on its side, securing it at probably 4 points to the roof bars.
surely my method is more secure (double the contact points), and results in less wind resistance, as the bike is horizontal, closer to the car roof, rather than vertical, plus the reduction in the side wind forces.
FWIW the front wheel would be off, as i can't be bothered to turn handlebars etc
the roof rack is specific for the ford ka, and as such is definitly suitable.
sorry if i sound a bit thick!
Posted : 03/05/2010 3:34 pm
Be careful of low gateways and overhanging branches, as your car will be slightly taller
Posted : 03/05/2010 3:35 pm
I have done this a few times with no problems whatsoever. Just put some padding in and be careful tying it down. You are absolutely right that bikes lying down will have less forces trying to pull them off compared to upright bikes
Posted : 03/05/2010 3:39 pm
thanks TJ, its a tandem i'm thinking of attaching...
gephaudio, the car is pretty low down as it is, i don't think height will be too much of a problem 😉
Posted : 03/05/2010 4:08 pm
Your top speed and fuel economy might take a hit, too. I had 2 (admittedly large) surfboards on the roof of my Ka and it struggled to hit 65 on the motorway. It's ok though, 'cos everyone knows small cars with big things on the roof = cool.
Posted : 03/05/2010 4:37 pm
aye, i've decided that i'm not going to drive like i'm 70, at 60 on the motorways... 80 in a ka drinks fuel 🙁
Posted : 03/05/2010 5:15 pm
