Is it possible to use current spec spacers to reduce the travel on an old set of toras?
2006 tora 302 solo air- originally would have had either a 30mm or 50mm spacer to lower from 130 to 100 or 80mm.
Will current 20mm spacers for revs etc fit or do I need to put a WTD ad in the classifieds?
Bump for the morning people
Completely different spacer I think much smaller in o.d as the airspring run within a airtube within the the fork leg. Solo and Da alloy upper leg forks basicaly run a different air spring but I could be wroung as to there swap ability. I know ones made of rubber and ones plastic I will measure some for you.
Cheers slinky
