Rockshox - swapping...
[Closed] Rockshox - swapping crown lockout for pushloc
3 Users
I have a set of rebas with a crown mounted lockout (threshold adjust etc) and an older set of pikes with a pushloc that i've never used.
Can I simply swap the entire cartridge thingy between the forks and use the older pushloc with the bar remote on the new set of rebas and have the crown mounted lockout on the old pikes?
Are they all cross-compatable?
Posted : 06/07/2013 4:16 pm
Yupp. Can't see why not.
Posted : 06/07/2013 4:20 pm
As far as I know it's not that straight forward mate. The damper/Motion Control part 'may' not be cross compatible. If you're lucky it might work but worth checking with the SRAM Service Centre. They'll ask for the models of fork, serial numbers etc and give a definitive yay or nay. All I know for sure is that there are different dampers for the fork models, so you might be lucky, might not. Hope it helps mate.
Posted : 06/07/2013 5:15 pm
Thanks, will drop them a mail and check it out before i randomly pull stuff apart!
Posted : 07/07/2013 9:31 am
