Rockshox SID XX Adv...
[Closed] Rockshox SID XX Advice
2 Users
Hi
I have a Rockshox SID XX 120mm fork and was wondering if it is possible to change the travel to 100mm. On the fork itself it does have the travel makings for 100mm and would it be just a case of changing an internal spacer? If so anyone know what/where the spacers are available from?
Posted : 14/08/2013 11:52 am
If they are solo air you'll need a new air spring assembly at £70ish plus fitting if you're not spanner enabled. Loco can sort you out.
Posted : 14/08/2013 12:16 pm
