Rockshox Sektor R s...
[Closed] Rockshox Sektor R solo air
4 Users
 hora
Hovering over the checkout.
R model not the TK. Thoughts?
Posted : 02/04/2013 7:40 pm
Had some on my nickel, for the money a good fork, stiff ish with the 15mm maxle, easy to set up & quite plush. Good fork for the money. Don't think you'll find much better.
Posted : 02/04/2013 7:53 pm
 hora
These are 20QRs so a brucey-bonus then 8)
They are also 2lb lighter than my 05 Z1 FRs
Posted : 02/04/2013 8:02 pm
I've got Solo Air RL with 20mm Maxle (150).
Excellent forks. How much you seen em for?
Posted : 02/04/2013 8:21 pm
Got some, but changed out all the damper bits for Rev ones (dual-flow rebound and an RLT comp. damper). Cost less than just buying a Rev RLT from Merlin and, as you said, the 20mm Maxle is a bonus. I ran it in stock form for a couple of weeks and it was alright. Bit divey due to lack of comp. adjustments, but the stock rebound unit is the same as old Moco ones, so it does alright. The Dual-flow is fantastic though.
Edit: should say that it was always my intention to change out the dampers (just really wanted a 20mm Rev), so it's not like I thought it was so bad in stock form that I had to do it.
Posted : 02/04/2013 8:23 pm
 hora
FFS man buy, buy, buy. 😯
Posted : 02/04/2013 8:24 pm
 hora
Warpcow me too. 70? Later on for the dual flow asym from loco
Posted : 02/04/2013 8:34 pm
