RockShox Reverb Ste...
[Closed] RockShox Reverb Stealth - Connectamajig
4 Users
I have a new 2017 Reverb Stealth that has the Connectamajig, this means it doesn't go into my frame far enough. 😡
Is it possible to connect the remote to the reverb without the Connectamajig?
Posted : 05/08/2016 7:23 am
Found the Reverb Manual... Yes is the answer, it can be connected with or without the Connectamajig, that means I should get it further in the seat tube by 1-2"... Possibly.
Posted : 05/08/2016 7:35 am
You need an £8 part, have a read through this
[url= http://singletrackmag.com/forum/topic/unique-reverb-fitment-problem ]http://singletrackmag.com/forum/topic/unique-reverb-fitment-problem[/url]
You can certainly get another inch or so
Posted : 05/08/2016 7:39 am
Aye, I've done just that- connectamajig is just an extra point of failure as far as I'm concerned so I got rid of it. Extra shortness could be a bonus, made no difference in my bike.
Posted : 05/08/2016 8:36 am
What does the connectamajig do, exactly?
I jsut swapped a hose, and lookign at the videos, the procedure for dosconnecting a regualar hose is - unscrew the hose,
The procedure for disconnecting a connectamajig hose is - unscrew the hose
It might save youa bleed - but I doubt it - pretty much every scenario that involves disconnecting the hose involves a bleed
Posted : 05/08/2016 8:40 am
It is intended to save you from having to bleed the hose but since they say it only works for about three disconnections I have to wonder just how good it is. Plus it only allows you to remove the post since the connectamajig doesn't fit through any stealth hole I've seen and I can't say I find it a great benefit. Bleeding the hose isn't exactly difficult so long as you have a kit
Posted : 05/08/2016 8:50 am
