Rockshox Revelation...
[Closed] Rockshox Revelation RTL Ti..Have I brought the wrong thing?
6 Users
I have just taken delivery of these fork and had thought they had adjustable travel on the fly 120-150 however the instructions with them are none existent and the SRAM web site talks about 30mm "sag" adjustment and off the bike they do not seem to have adjustable travel just adjustable compression.
I wanted a travel adjust fork like the Fox Talas.
Have I brought the wrong thing ?
Posted : 30/03/2011 5:35 pm
[url= http://www.on-one.co.uk/i/q/FORSREVRLTTIDP/rockshox-revelation-rlt-ti-dual-position-air-150mm-fork ]http://www.on-one.co.uk/i/q/FORSREVRLTTIDP/rockshox-revelation-rlt-ti-dual-position-air-150mm-fork[/url]
these have a 30mm adjust I believe but you can only have 150mm or 120mm (with on the fly adjustment between them) is that what you wanted?
Posted : 30/03/2011 5:41 pm
yes that what I wanted but with the correct pressures in them and compressing them against the carpet they seem to return to the same level wherever the compression adjust lever is and there is no other adjustment
Posted : 30/03/2011 5:48 pm
link to the item you bought?
Posted : 30/03/2011 5:50 pm
lever on the left? If not it's no dual position. Have a DP Worldcup, adjust works fine.
Posted : 30/03/2011 5:55 pm
http://www.sram.com/rockshox/products/revelation-rlt-ti
no lever on the left
Posted : 30/03/2011 5:58 pm
the one you linked to has the lever?
was it an OEM one - where did you get it?
Posted : 30/03/2011 6:01 pm
you have bought RLT Ti Dual Air.
you want RLT Ti Dual Position.
HoratioHufnage
I think you've got it thanks
Posted : 30/03/2011 6:53 pm
 br
from on one?
Posted : 30/03/2011 8:20 pm
