I have a set of coil converted 2010 revelation teams. They currently leak oil from the compression knob. I am assuming that fluid is escaping around the floodgate adjuster, as the main cartridge seal is static so not prone to wear. Having stripped the blackbox damper, I am guessing that the seal that seals the floodgate system against the top cap of the damper has worn out. This seal is not a simple o ring, but a rubber band doubled over (kind of thing) and I can not seem to find any information on what to replace it with. Does anyone have any suggestions?
Many thanks.
not sure if this kit includes what you need?
Thanks a lot! That looks promising. Just ordered.
