RockShox Recon leak...
[Closed] RockShox Recon leaking oil question....
2 Users
Recently serviced a pair of 2007 Recon coil u-turns. Now they're leaking oil out of both legs. They don't as far as I recoil have the black oil seals in.
So, if I replace the dust seals will that stop it? Have I simply over filled them with oil? (don't recon so).
The stanchions are in perfect condition.
What should I try first?
Posted : 16/07/2013 12:46 pm
Where are they leaking from, the top at the seals or the bottom at the bolts?
More info needed.
Posted : 16/07/2013 1:09 pm
Top of the seals.
Posted : 16/07/2013 1:13 pm
RS recommend a seal change with every service. You can get away with not doing so if you are careful & they are not too old.
Sounds like yours are due a change.
Posted : 16/07/2013 3:06 pm
