Rockshox Reba Trave...
[Closed] Rockshox Reba Trave Adjust Question
2 Users
Before everyone jumps in and says use Peters guide I have for forks up to the 2009/10 range - And a very good guide it is too
I recently bought some 2011 Reba Team forks. As always in the box came a couple of plastic travel adjust spacers.
The "thing" is the older spacers were "C" shaped and so they clipped on and off in use.
Like the black one in the picture here:
The newer spacers are doughnut shaped and look to need threading on albeit without a thread.
Can anyone advise.
Want to know what I will face if I open the forks!
Cheers All
Posted : 22/07/2011 12:57 pm
If they are dual air take the easy option and add a few extra PSI to the negative air, will bring your travel down to whatever you desire.
Posted : 22/07/2011 1:09 pm
Cheers PB but no good for upping the travel 😉
Posted : 22/07/2011 1:19 pm
Okay same process as the C shape ones but you just need to slide the bottom cap and bump stop off the dual air rod to get at it.
Posted : 22/07/2011 1:22 pm
