Hi All
Just got a set of Rockshox Reba RL 2011 off Merlin just wondered how I tell they are 120mm before I install them on my bike?
the stanchion leg measures 120mm from top of seal to bottom of crown is that correct?
anyone got a pair they can measure?
Let all the air out of the negative side, put a bit in the positive...... mine measure about 125mm
Like Stan says. If the negative is high it will drag down the travel so there may not be 120mm showing.
The pair of 120mm Rebas sat with me at the moment have only 110mm showing...probably time I checked the air pressures 😳
Cool thanks for your help chaps.
