Rockshox Pike
[Closed] Rockshox Pike
5 Users
Howya folks?
Just upgraded to a Slash 7... It's my first bike with proper adjustable suspension
I've a rockshox pike up front and am setting up my preload. Which of the measurement markings do I use? The 150mm travel or the 160mm
And while yer at it let me know why there's 2 markings on there
Thanks
Posted : 22/07/2016 7:30 am
using a token? Needs at least 1
Posted : 22/07/2016 7:34 am
They come in 150mm and 160mm, so you need to find out how much travel yours is, and use the markings for that to set sag etc.
Posted : 22/07/2016 7:37 am
The crown/steerer/uppers are the same on 150mm and 160mm forks. Use the sag indicator for whichever travel forks you have - should say on reverse of upper slider.
Posted : 22/07/2016 7:39 am
Cheers lads, the specs online say 160mm, but when I got her both markings were on the forks so was a wee bit confused
Had my preload set for the 160 markings.
Managed to bottom out the forks the last eve so gonna put in a token or two over the weekend and go through my setup again
Thanks for the info
Posted : 22/07/2016 7:53 am
With no load on it it should be reading 0%, so that should tell you what length forks you have.
Posted : 22/07/2016 9:54 am
