Rockshox Pike 2016 ...
[Closed] Rockshox Pike 2016 Rebound issues
4 Users
Hi,
I can't adjust the rebound on my Pikes. I have taken the rebound knob off and cleaned it up. There is quite bit of corrosion damage to the hex. I can turn the rebound 3 full turns with a 2.5mm allen key without friction and the rebound seems to be doing its job. However, when i put the rebound hex in, i can only get about plus/minus quarter turn with quite a bit of friction.
Anyone else had this? Is there a fix or should I return under warranty?
Thanks
Posted : 13/11/2016 7:43 pm
Anyone?
Posted : 15/11/2016 8:37 pm
The good news is the issue seems to be related to one of these parts:
Can you try removing the O-ring on the outside of the shaft bolt and the set screw of the adjuster button?
Does the spring under the detent ball in the button work correctly?
Posted : 15/11/2016 9:03 pm
Cheers, i'll try and get back to you.
Posted : 15/11/2016 9:57 pm
Posted : 15/11/2016 10:08 pm
Will be the 2.5mm hex on the red adjuster grabbing the rebound needle. Bet it turns easily with a 2.5mm allen key instead of the adjuster.
Posted : 15/11/2016 10:26 pm
Sure does, full 3 turns with the allen key only. Haven't a chance to try otsdr suggestion yet but will do.
Posted : 16/11/2016 10:16 pm
So.. spring under detent ball works fine. However, removing o ring and grub screw does not make a jot of difference. Not sure what is going on at interface between hex key and bolt where a 2.5mm allen key works fine!
Posted : 20/11/2016 7:58 am
 Bolt
Possibly the grub screw on the adjuster catching the foot Bolt, I have had this before.
If you push the adjuster in toward the fork while tightening the grub screw it may help to position it.
Posted : 20/11/2016 8:26 am
